What he describes as a problem is exactly what they do and what they sound like with the firing from the coils reversed or the cams 180 off.
I wondered as you mentioned swap wires and not which ones so I asked.
As you may recall the feller the other day who saw the colors at the coils were wrong and was slightly confused. (wire diagram didn't agree with his bike)
I suggested he check the color location at the points and he found they were reversed also.
Runs fine with not problem.
In both cases we shared the same knowledge with members but in a sort of different way. ...........................lm
G-Man wrote:LM - It's easy for me to say yes after the event but I have found, over the years, that it's worth reversing things even if you are 'convinced' that they are correct.
A couple of weeks ago I helped a neighbour fix his diesel tractor which had just had a re-conditioned pump. Spent a load of time bleeding the system but nothing coming out of the injector lines. Eventually I set the run/stop control to 'stop' instead of 'run' and it started right up. He just has to remember now that the control works backwards. I still cannot fathom how they changed this around when they serviced the pump.
LOUD MOUSE wrote:Are you recommending the wires from the controller to the coils G?. ........................lm
G-Man wrote:Hi Seadog
Great work as the guinea-pig on this.
I hate to suggest this because of your diligence and LM's expert help but have you tried just swapping the wires for the two cylinders?
In my experience, any electrical problem involving two wires needs at least three swaps to get the connection right......:-)
Seadog wrote:Got everything back together this afternoon and tried to start the bike. No go. Lots of backfiring through the left exhaust and popping through both carbs, but nothing. Reset the timing repeatedly with no effect. Checked all wiring. Ended up stripping the Sachse sensor wires out from between the stator windings. Perhaps interference is the culprit. I'll try starting it again tomorrow with the sensor wires exposed. I'm tired, but not beaten. If it fails to start again, I'll reconnect the points, then see how it goes. On the plus side, I can now install an exhaust system in under 5 minutes. :-)
