CA77 Lamp conversion
Post by Seadog » Sun Mar 22, 2015 10:55 am
deafanddiabetic wrote:No problem with the reflective coating, I think mostly because the soldering was all applied to the back of the contoured casing. I'm pretty sure I used Rosin Core 60/40. It's held on, taken the heat, and seems like it's working alright. It was pretty shoddy and quick, honestly totally on the fly one afternoon in the dungeon and now I see that others have tried the same method with success.
Thanks for that info.
The headlight is almost ready for paint. I'll have to get something heat resistant.
A little clean-up, then paint
Post by Seadog » Mon Mar 23, 2015 11:53 am
Done. 3 coats of heat resistant primer and 3 top coat. Not perfect, but ok.
Post by Seadog » Sun Mar 29, 2015 8:44 am
I'm pretty much done with this project now. I had to make a new wire bail for the bulb, since the original wasn't bent in a way that held the bulb in place for this application. I also bought an LED bulb and bent the tabs for fit into the headlight bucket. After a long search, I finally found the .375" wide female spade connectors locally and soldered them to the existing wires. I tested the light with a battery and all is well.
Post by Seadog » Mon Nov 09, 2015 4:47 pm
I thought I'd try to convert a CB77 headlight….
How the bulb holder will sit.
Hole refined.
Hole refined.
Rough hole cut.
Rough hole cut.
Marked for hole enlargement.
Bulb removed
Bulb removed
Post by G-Man » Mon Nov 09, 2015 4:54 pm
Great work!
Does anyone know why American Hondas used those crazy sealed beam headlights when the rest of the world got headlamps with replaceable bulbs? Was it a legal thing or some other reason?
Post by Seadog » Mon Nov 09, 2015 4:55 pm
Continued.
Installed.  I'm waiting for an LED bulb.
Painted.
Painted.
JB Weld shaped and sanded.I wish I was able to feather the edge of JB Weld like I can Bondo.  The edge just crumbles.
JB Weld applied and rough shaped with a dental tool.  I drilled 3 ⅛" holes in the bulb holder and forced JB through for greater holding power.
Post by Seadog » Mon Nov 09, 2015 4:57 pm
G-Man wrote:Great work!
Dunno, G. Probably so they could soak more $ out of us.
