Which would be less expensive - BUY a key for my CA77 ignition, or take it to a locksmith and have one made? OR - just get a go-cart keyed ignition on the 'Bay for $6?
Or what are you using...?
I guess the cost is about the same, yes...?
Keys - Buy or Build?
Dr. Frankenstein
The stock switch serves as the headlight on/off switch and engages additional charging coils when the headlight is on.
Best not to try and replace it with a simpler switch type.
Some ebay vendors supply keys matched to the lock number, or a member may have a matching key?
Re: Keys - Buy or Build?
What are the numbers on the switch?
I have some keys and will see if I have that key. ..............lm
Dr. Frankenstein wrote:Which would be less expensive - BUY a key for my CA77 ignition, or take it to a locksmith and have one made? OR - just get a go-cart keyed ignition on the 'Bay for $6?
Dr. Frankenstein
One here.....
https://www.ebay.com/itm/NOS-Pre-Cut-Ho ... :rk:2:pf:0
Dr. Frankenstein wrote:The number on the ignition is T0644, if that helps.
