In need of replacing the 3 screws that hold the stator cover m5 x 15. I ordered up some oval head screws that arrived today and although they do the job the head of the screw is slightly smaller that the original.
Does anyone have a link where I can get some.
Thanks.
CA77 Stator cover screws
mcconnellfrance
Casamere,
Presuming it is a CB72/CB77, the part number is 93700-05016
David Silver Spares have some.
https://www.davidsilverspares.co.uk/par ... 00050160A/
Regards
Regards
- Tim Allman
Be wary of the thread pitch. 5 mm screws from before the switch to ISO (also called New JIS by Honda) had a different pitch than the current ones do. I purchased a set from DSS thinking that because they said they would be useful, they would be. They weren't. My solution was to run the right die up them to produce screws with two threads. I wouldn't do that if strength were an issue but for the cover it seems a reasonable kludge.
