New to the forum here, and to CA77's in general, but have tinkered with lots of bikes. Bought a 67 CA77 out of a barn it had been sitting in since 1983, got it running, everything appeared to work great.
Second time firing the bike, low beam stopped working, flipped up to high beam and it worked for a short while, then it too, stopped working. The bulb appears to be good. Measured voltage at the headlight, no 12v.
Are there fuses I am not seeing? Could it be in the switch? Any advice would be greatly appreciated!
Headlight stopped working
Disconnect the wires to the bulb and put a meter across on the Ohms range. Do you get a reading?
Was the engine running or not when the bulb(s) stopped working?
Seadog wrote:There isn’t, I was thinking CB77. The rest of my post is fine. Check the ignition switch connections for corrosion too.
vossler wrote:Where is the headlight switch on the headlight housing located? I don't recall seeing a switch there.
