I will say again that I remain TOTALLY convinced that ALL Dream sticky twist throttle issues are aggravated by an inherent design problem - that is, the adjuster being located mid-cable.
When adjusted out, the two separate OUTER sheathes have a (1/2" to 1") gap at the adjuster. This allows that unsupported length of inner cable to BEND slightly at the adjuster - that combined with the forced "push" that happens with the twist throttle grip design itself causes a bind point that is seen as slow or sticky throttle.
Save yourself a LOT of grief and use a CB72 external throttle with a 262-000 cable and fix the problem for good. Once you do it you will find that the throttle snaps back like a new bike!.
1964 Honda Dream 305 Sticky Throttle
danielzink
Did this last year on my Dream and couldn't be happier....ebay for both parts and you'll be amazed at the difference...OldHarley wrote:I will say again that I remain TOTALLY convinced that ALL Dream sticky twist throttle issues are aggravated by an inherent design problem - that is, the adjuster being located mid-cable.
Dan
- Muddy
What a great tip!OldHarley wrote:I will say again that I remain TOTALLY convinced that ALL Dream sticky twist throttle issues are aggravated by an inherent design problem - that is, the adjuster being located mid-cable.
'64 C72
'62 C72
'62 C72
staggerwing
Thank you for the advice! I can't imagine riding this bike with any faith that I have control over the throttle as one should. It certainly is a bad design.
I looked on eBay and saw some cables. Not quite sure what the throttle grip should entail. I can see how the cable attaches to it but I didn't see how it attaches to the handlebar. I assume it has a different collar than the original CA77 one? Any pictures available from someone that has done this retrofit? I'm sorry. I'm a newbie!
Nathan
Nathan
danielzink
Mounts the same way as the stock throttle.... 2 piece...clamps around the bars...staggerwing wrote:Thank you for the advice! I can't imagine riding this bike with any faith that I have control over the throttle as one should. It certainly is a bad design.
Nathan
danielzink
staggerwing
