Front fork spring guides
Post by Seadog » Wed Jan 17, 2018 4:59 pm
Thank you, Al. I’ll make a couple up when I find suitable material.
AlanW wrote:95mm long, 35mm to slide inside the spring, 45mm on the end to go over the spring top.
I just went to the workshop and measured one.
Al.
AlanW
Post by AlanW » Wed Jan 17, 2018 6:18 pm
You are welcome Seadog, I forgot to mention that the thickness of the material is 0.5mm.
Post by Seadog » Wed Jan 17, 2018 6:38 pm
Thanks again, Al. I’ll post my results when I get to the job.
modelman
Post by modelman » Thu Jan 18, 2018 3:28 am
Our welding wire is supplied in these black polyprop tubes, they are 1m x 40mm & would probably be ok to make the tubes from, very easy to cut & heat-form the flange, trouble is, we throw them away!!
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
AlanW
Post by AlanW » Thu Jan 18, 2018 5:06 am
Hi Modelman, that should work ok.
Al.
cknight
Post by cknight » Thu Jan 18, 2018 8:37 am
I've made a few sets of these using industrial plastic shim stock. This is used for leveling precision machinery, so it's very durable. AccuTrex Practi-Shim is a popular brand here, and their yellow colored stock is 0.020" thick, close enough to 0.5mm. Thicknesses from 0.0005" to 0.030" are available. You can cut it with scissors, or a good blade. It comes in handy for many purposes, including reducing swingarm side play. Regards, Chase
Post by Seadog » Sun Apr 01, 2018 10:01 am
I got around to fiddling with my Type II front forks today. I found the main bodies of the spring guides on each leg, but the flanged/tab portions were gone. I found most of the broken tabs mashed into the top of the seal support in the chrome lower case cover. It appears that someone installed them at the bottom of the spring instead of the top. Flattening one guide out, I found that it measured 104mm wide. Then, using the height dimensions posted by AlanW (thanks again), I made one new guide up using gasket material. 95mm high, with the tabs 5mm long. I simply counted the number of tabs on G-Man's photo - 21 - and cut that number of tabs evenly spaced. The guide came out well, but I'll need better material. I think I'll get some shim stock, as Chase recommended. Results below:
