The hole fits into 1st gear not like you have in the 3 rd pic. .............lm
AZscrmblr wrote:I decided to replace the 14mm bushing while I had the transmission open. When I compared the old bushing to the new one I found that there is a difference in the ridge in the center of the bushings (1st photo). The old one is thinner and has a taper on the side that goes into 1st gear (bushing on right in 1st photo). The taper matches a taper in the gear (2nd photo). The new bushing is flat on both sides of the ridge. When it is put inside the 1st gear, it does not go in as far (3rd photo).
Is this going to cause a binding problem? I did a search on the bushing and found quite a lengthy discussion but am not certain as to the final conclusion.
DSC04228 by Gary Snell, on Flickr
DSC04231 by Gary Snell, on Flickr
DSC04233 by Gary Snell, on Flickr
