Recently went through and cleaned up the clutch plates and basket, and bought what i think are the proper friction plates. After putting them the plates in the basket and tightening down the cover, it appears the plates have a bit too much "play"
This lead me to place one of the old friction plates up to the new ones and the new ones seem to be just a smidge smaller than the old ones.
Also i noticed the friction pads are different between the two, which i assume won't matter but have attached a picture anyway.
My main concern is the difference in width of the plates.
Any insight is appreciated
Clutch Friction Plates
bweed2112
- Comparison of friction pads
- 20170409_144917_1491784980824_resized.jpg (139.18 KiB) Viewed 5330 times
- Comparison of size of discs - old outside, new inside
- 20170409_145117_1491784978788_resized.jpg (159.32 KiB) Viewed 5331 times
Re: Clutch Friction Plates
Looking at the side pic I'd say you may not have put the thickest steel plate on the center hub first.
Followed by friction/steel.
The pic of the first friction disc is corrrect for this clutch.
If you need that old friction disc you don't have this clutch assembled correctly. ......................lm
bweed2112 wrote:Recently went through and cleaned up the clutch plates and basket, and bought what i think are the proper friction plates. After putting them the plates in the basket and tightening down the cover, it appears the plates have a bit too much "play"
bweed2112
I will double check, but i'm 90% sure the thickest steel plate was put on first.
By first friction disc do you mean the one on top of the second picture?
I don't need the old friction disc there, its just there for comparison. I used the parts catalog to know what order to put things back together.
Any idea of where i can find the proper friction discs for this clutch?
Yes. By first friction disc do you mean the one on top of the second picture?
I have all the clutch parts you will need. ............lm
bweed2112 wrote:I will double check, but i'm 90% sure the thickest steel plate was put on first.
bweed2112
LM, here are the pictures you requested. I believe the only part that i forgot to take a picture of was the set-ring.
Let me know if there are any other parts that you think i should replace.
- 20170409_215738_1491824686844_resized.jpg (128.74 KiB) Viewed 5290 times
- 20170409_215840_1491824685330_resized.jpg (107.31 KiB) Viewed 5290 times
- 20170409_215920_1491824688514_resized.jpg (164.57 KiB) Viewed 5290 times
- 20170409_220413_1491824681442_resized.jpg (132.38 KiB) Viewed 5290 times
- 20170409_220508_1491824683623_resized.jpg (153.29 KiB) Viewed 5290 times
