My Diamond is still rough
barnbiketom
Post by barnbiketom » Tue Mar 28, 2017 10:34 am
But even Honda makes mistakes?????!
I like stock...
A few modern mods...
But worst of all are those gawl dang PODS
barnbiketom
Harbor FRIGHT Bike Lift!!!
Post by barnbiketom » Thu Mar 30, 2017 9:57 am
I wholeheartedly RECOMMEND this bike lift. It raises a bike 32 inches off the ground, and has lock pins, and takes up no space..
In this pic, it is only halfway up, but perfect with my swivel tool seat!!
ALSO it can be used to lift the front of my lawn tractor off the ground for blade maintenance....
I've lifted a Vulcan 1500 with no problems altho i used the safety straps on that one lol...
IMG_20170329_130043 (Small).jpg (76.62 KiB) Viewed 3718 times
I like stock...
barnbiketom
Led!!
Post by barnbiketom » Fri Mar 31, 2017 9:43 am
I decided on a $10.00, 800 lumen LED H4 bulb. I had converted to a unit from an xs400, although any 6 3/8" H4 assembly will fit perfectly into the Cl77 headlight rim.
This style bulb has a built-in heatsink and fan?? Inside the headlight, not on the back so there is clearance, but you still need to bend flat the terminals and make a new Spade connector harness adapter, so it clears the speedo cable!
This style bulb has high ratings all over the 'net and some sellers are getting $25 bucks, but I saw it for $9.99 so I figured I'd try it. It is blindingly bright white and low beam and high beam gives two distinct levels at 25 feet when aiming. I haven't ridden it at night but I'll post my findings..But you will really be noticed in the day!!!!!!!!
BEWARE the el cheepo h4 LEDs all over the place. they are dimmer than a candle unless they have a remote power supply and a fan..
I like stock...
barnbiketom
Spring
Post by barnbiketom » Sun Apr 09, 2017 2:44 pm
Spring on remaining one loose too
I like stock...
Re: Spring
Post by LOUD MOUSE » Sun Apr 09, 2017 2:47 pm
DO you have the square and is the slot in the knob opened?. ..............lm...............lm
uote="barnbiketom"]Spring on remaining one loose too[/quote]
barnbiketom
Re: Spring
Post by barnbiketom » Sun Apr 09, 2017 3:04 pm
LOUD MOUSE wrote:DO you have the square and is the slot in the knob opened?. ..............lm...............lm
[/quote]
Yes I have the 1 square and the knob an pin is ok. Missing everything on other one tho
I like stock...
Re: Spring
Post by LOUD MOUSE » Sun Apr 09, 2017 3:06 pm
I'll cut another spring and replace all the other parts. .............lm
Yes I have the 1 square and the knob an pin is ok. Missing everything on other one tho[/quote]
