Speedometer Packing
Speedometer Packing
Post by Seadog » Fri Mar 24, 2017 8:20 am
I'm replacing the speedo packing on my CB77 today and found that the old one was glued down with something I cannot identify. Maybe rubber cement? Anyone have any idea what this stuff is? Is the packing supposed to be sealed to the chrome speedo ring at all?
HondaPaul
Post by HondaPaul » Fri Mar 24, 2017 11:52 am
I can't say I know what it is or exactly why its there, but I used a thin coat of black silicone when I replaced the packing on my CL77.
Paul
Post by Seadog » Fri Mar 24, 2017 1:23 pm
Thank you, Paul. Wherever it was cleaned up nicely with acetone on Q-tips. I have some clear silicone I'll use sparingly when I reinstall the packing. As a note to anyone reading this, my packing definitely has a front and back. Best to dry fit first.
Hoosier Tom
Post by Hoosier Tom » Fri Mar 24, 2017 4:36 pm
Seadog,
It's like weatherstrip adhesive, and that's what I use. That bracket and rubber mount to the bucket so the speedo needs something to bond it to the rubber to keep it from moving around.
HT
Post by Seadog » Sat Mar 25, 2017 11:53 am
Thank you, HT. I ended up using a black silicone general purpose Permatex adhesive sealant that's for exterior use. It needs to cure for 24 hours, then I'll reinstall.
Hoosier Tom
Post by Hoosier Tom » Sat Mar 25, 2017 3:55 pm
You're welcome.
HT
