Oversize head gasket
CharlesM
Post by CharlesM » Tue Mar 14, 2017 6:13 pm
I race a CB72 bored to 64mm. I am finishing the refresh and need to replace the head gasket. Last year I used a CB77 standard gasket, which was ok, but the edge of the piston just clips it Boretech in the states do a 66mm gasket, but that's about 150$ to get it to England.
Having gaskets made will be about £100 to set up the tooling as a minimum.
Any ideas on suitable alternatives? So far, my plan is to use a CB77 gasket again.
Post by G-Man » Wed Mar 15, 2017 3:05 am
Hi Charles
Have you talked to anyone about laser-cutting you a copper one? Apart from getting a drawing done and the cost of the copper it shouldn't be too expensive.
http://www.barnwell.co.uk/products/gask ... materials/
These guys could probably adjust the bore size of this part...
http://www.ebay.co.uk/itm/HONDA-SUPERHA ... 25b5cdfbb8
malcolmgb
Post by malcolmgb » Thu Mar 16, 2017 5:26 pm
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
lloydy1
Post by lloydy1 » Fri Mar 17, 2017 3:20 am
Hi Charles
I made one up myself....made a template up and cut it out of a copper sheet.
Dave
