New member with '66 CL77
Tim Miller
Post by Tim Miller » Fri Jan 27, 2017 3:40 pm
This is the early CL72 pan that's setup for buckle seat strap. Also those are the fragile early spikes.
Brent Davison is the owner for Scultgarage has best and only complete foam and cover kits available anywhere. He has them listed on eBay. I know this because I helped him with building all the many prototypes, he also has my bikes in his add. If you need a later version pan I can help. PM me.
Tim
Glenn-N wrote:Is there a difference in CL72 and 77 seat pans?
Got this one laying around waiting for a fresh powercoat.
Still has the original spikes if I'm correct.
Now I only need a new foam, cover and the trim.
Post by LOUD MOUSE » Fri Jan 27, 2017 3:43 pm
Hello Glen.
There is a difference between the early and late CL72/77 seats.
I recommend you remove yours and compare the front of this this pan to the one on the bike.
I doubt they are the same. ...............lm
Glenn-N
Post by Glenn-N » Sat Jan 28, 2017 7:13 am
Tim Miller wrote:This is the early CL72 pan that's setup for buckle seat strap. Also those are the fragile early spikes.
Tim
Thanks Tim.
I was planning getting a seat kit from him to restore it but offcourse I need the correct seatpan.
Will send you a PM.
I was drooling on the bikes from the add... They look fantastic.
Glenn-N
Post by Glenn-N » Sat Jan 28, 2017 7:15 am
LOUD MOUSE wrote:Hello Glen.
Thanks Ed.
The seat mounted on my bike is a replica seat. Doesn't look too bad but the fit is not perfect.
At the front it pushes against the gastank and the double C-clip doens't fully get around the mounting point on the frame.
Tim Miller
Post by Tim Miller » Sat Jan 28, 2017 1:02 pm
You could actually use this pan if you weld a couple 6mm studs over the 10mm holes to anchor the later strap.
Thanks for the compliment!
Tim
Tim
Thanks Tim.
Will send you a PM.
Glenn-N
Post by Glenn-N » Mon Jan 30, 2017 2:47 pm
I've been wanting to mount the "300" badges from Ray Byrne for a while since I just don't like the metal replacement badges from Honda.
However... it always seemed I received the wrong screws from different sellers... Thought I got ISO again and again because they didn't fit.
Left: my old screws that fit
Right: JIS screws from Ray Byrne
There seems to be a very small difference in pitch?
malcolmgb
Post by malcolmgb » Mon Jan 30, 2017 4:43 pm
copy of Honda JIS to ISO thread changes.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
