Dick Eastman
Post by Dick Eastman » Sun Jan 08, 2017 7:30 pm
border0_3 wrote:This is a neat mod Dick.
Are you going to use the disc brake as well?
Cheers-Richard
Thanks, Richard, the seller had the wheels from the CX, Comstars. I am trying to keep the look of a '60's- era track bike, with drum brakes. The caliper bosses on the slider will give me a mounting point for the brake arm. Also, I may work up mounts for a hydraulic steering damper.
Dick Eastman
Post by Dick Eastman » Sat Jan 21, 2017 5:58 pm
Powder coated swing arm, center stand, triples; made new steering stop for CX forks - had to measure the stop-to-stop arc on my other cb77 - about 77 degrees, then weld stop to steering head. Made a brake torque arm for front, similar to rear arm, and made appropriate spacers for brake backing plate and caliper mount on slider - this was after I made a spacer for front axle to center CB wheel on CX forks.
I removed the fork tubes from the sliders to replace seals, and put the sliders on the lathe to turn the necks to same diameter for a fork brace - I had one on my ZRX Kawasaki, and it did make a difference. Getting ready to paint sliders and brake backing plates.
powder coat triples, SA, stand 010 (Medium).jpg (64.02 KiB) Viewed 16200 times
powder coat triples, SA, stand 009 (Medium).jpg (40.11 KiB) Viewed 16200 times
powder coat triples, SA, stand 008 (Medium).jpg (45.83 KiB) Viewed 16200 times
powder coat triples, SA, stand 007 (Medium).jpg (60.13 KiB) Viewed 16200 times
powder coat triples, SA, stand 006 (Medium).jpg (66.12 KiB) Viewed 16200 times
Dick Eastman
Post by Dick Eastman » Sat Jan 21, 2017 6:02 pm
A few more pics
powder coat triples, SA, stand 005 (Medium).jpg (29.04 KiB) Viewed 16193 times
powder coat triples, SA, stand 004 (Medium).jpg (49.39 KiB) Viewed 16193 times
powder coat triples, SA, stand 003 (Medium).jpg (25.54 KiB) Viewed 16193 times
powder coat triples, SA, stand 002 (Medium).jpg (36.85 KiB) Viewed 16193 times
powder coat triples, SA, stand 001 (Medium).jpg (52.85 KiB) Viewed 16193 times
Post by G-Man » Sun Jan 22, 2017 11:43 am
Great work, Dick!
Loving the red powder coat.
Muddy
Post by Muddy » Sun Jan 22, 2017 4:04 pm
Still very, very envious of the skills, equipment and time on display here. Great work - and yes, the red looks fantastic.
Thanks.
Regards
Muddy
'64 C72
'63 C72
Dick Eastman
Post by Dick Eastman » Sun Jan 22, 2017 7:53 pm
Thanks, guys.
The red is called "regal red", and is the identical color of Mac tool boxes. I periodically help at the powder coater's shop, and was helping when they had a run for Mac. I decided then that was the red for the frame, and recently they had another run, so I took stand, swing arm and triples there. I still have to fit the tank and seat to the frame, so I will have to weld mounting points before coating.
A few pics of the fork brace I made for my '01 Kawasaki ZRX1200R. This was when I was in a shop running cnc mills, so the one I have planned for my CB will not be as fancy. I will make this when I have the forks assembled, to get accurate dimensions.
This brace has some "bug guards", to keep the stanchions clean.
IMG_1677 (Medium).JPG (57.33 KiB) Viewed 16087 times
IMG_1676 (Medium).JPG (57.69 KiB) Viewed 16087 times
IMG_1675 (Medium).JPG (69.64 KiB) Viewed 16087 times
IMG_1674 (Medium).JPG (63.56 KiB) Viewed 16087 times
IMG_1673 (Medium).JPG (46.14 KiB) Viewed 16087 times
Dick Eastman
Post by Dick Eastman » Fri Jan 27, 2017 9:36 am
A few more things accomplished: powder coat both fenders, fender brace, and fork sliders. The fenders are a natural aluminum color. The front fender is the '79 CX500, and the rear is an old aftermarket Beck/Arnley front fender for a 305 Scrambler, modified.
Because I can no longer use the stock steering damper, I have been considering a hydraulic rotary, like a Scotts. I put the frame on the mill to create a mounting point for the stationary post; I'll fine tune it with a post bracket when I actually have one in hand - at least the mounting pad is done. I cut the handlebar mounts off the upper triple, and will use the tapped holes for the damper...slowly but surely.
powder coat fenders,sliders, machine neck 008 (Medium).jpg (34.41 KiB) Viewed 15985 times
powder coat fenders,sliders, machine neck 007 (Medium).jpg (51.32 KiB) Viewed 15985 times
powder coat fenders,sliders, machine neck 006 (Medium).jpg (48.3 KiB) Viewed 15985 times
powder coat fenders,sliders, machine neck 005 (Medium).jpg (47.8 KiB) Viewed 15985 times
powder coat fenders,sliders, machine neck 004 (Medium).jpg (47.32 KiB) Viewed 15985 times
