My 1965 CL77
Post by LOUD MOUSE » Sat Jan 07, 2017 7:04 pm
Have you made sure the tubes are not bent?. ............lm
thepunisher2007 wrote:They look great. I have a pair i pulled off a donor bike this morning (cl72) they look solid just a lite surface rust but should clean up good. How do you get them apart?
Separate question ill ad pics to illustrate the point but im having issues with the front forks. is the supposed to be and angle on the top by the clamps. I have 2 pairs of 72 forks all seemingly good condition apart from 1 is a little rusty. all of them have the same angle. when i put them on the front forks separate to the point they have to be pulled in to meet the wheel. Something is definitely not right. None appear damaged and all the bends measure the same. Or is it correct and the forks just need to be swiveled in the clamp so that the angles of both sides match and in theory close the gap (note i haven't tried that)
The later style forks and wheels i used to start with didn't have this issue but all my early forks have the same bend to the milometer
the i rotate the fork 180deg
thepunisher2007
Post by thepunisher2007 » Sat Jan 07, 2017 7:18 pm
the only "bend" is the bit by the clamps but all of the early model forks i have are the same. it made me question if it was meant to be there.
Post by G-Man » Sun Jan 08, 2017 2:54 am
The forks have many different diameters and taper sections but they should not be bent.
thepunisher2007 wrote:the only "bend" is the bit by the clamps but all of the early model forks i have are the same. it made me question if it was meant to be there.
Post by G-Man » Sun Jan 08, 2017 3:06 am
Take a look at my thread from a few years ago for disassembly.
http://www.honda305.com/forums/dissasem ... 94-28.html
thepunisher2007
Post by thepunisher2007 » Sun Jan 08, 2017 9:57 am
i must be really unlucky then :( ill have to see if they can be straightened. Thanks for the info on the rear shocks
thepunisher2007
Post by thepunisher2007 » Fri Aug 18, 2017 11:02 am
Before
Before
Before
Photo 21-02-2016, 09 42 47.jpg (201.48 KiB) Viewed 2435 times
thepunisher2007
Post by thepunisher2007 » Fri Aug 18, 2017 11:07 am
After
After
After
Photo 17-06-2017, 09 05 241.jpg (342.25 KiB) Viewed 2431 times
