I got a "mini grease gun" from Harbor Freight... http://www.harborfreight.com/grease-gun ... 95575.html
If you use it on a standard zerk fitting it may not fit the small fittings afterwards.
Beginning Restoration
- jleewebb
grease gun
'62 CB77. "It's a rider."
Does anyone no where I can get a new set of mirrors for a 1967 scrambler? I bought a pair from Southside Honda on ebay, but when they are mounted on the bike, I cannot pivot the mirror low enough to see directly behind me. I compared them to the originals and it is obvious that the masts are bent at different angles. Southside claims these are the only ones America Honda offers. Does anyone know of a source for direct replacements?
Paul
Paul
Hoosier Tom
Those are the only ones available from Honda, as Southside indicated. Some people bend them to render them useable. I have bought 3 sets of the NOS Toyo mirrors from Private-Punchy on eBay several years ago when they were under $50 a pair. Now they are $84 plus $16 shipping, too rich for my blood. What he doesn't disclose is they are both right side mirrors that one of them had been heated and bent to be a left side. All three pair of mine were that way and when I look at his current listing I can see the twist on the one mirror stem. I am attaching photos of what that bend/twist looks like up close compared to the unbent right from his eBay mirrors. They worked ok on my Super Hawks. Sometimes decent, original mirrors pop up on eBay, usually as singles. Someone may be able to give you a source for OE style rectangular mirrors that fit without having to bend.HondaPaul wrote:Does anyone no where I can get a new set of mirrors for a 1967 scrambler? I bought a pair from Southside Honda on ebay, but when they are mounted on the bike, I cannot pivot the mirror low enough to see directly behind me. I compared them to the originals and it is obvious that the masts are bent at different angles. Southside claims these are the only ones America Honda offers. Does anyone know of a source for direct replacements?
Paul
HT
- Unbent right
- image.jpg (253.36 KiB) Viewed 4347 times
- Bent/twisted right to make a left
- image.jpg (133.2 KiB) Viewed 4359 times
I got a set from Thailand on eBay look like stock (rectangular). $14.99 + $14.99 shipping. The quality was pretty good.HondaPaul wrote:Does anyone no where I can get a new set of mirrors for a 1967 scrambler? I bought a pair from Southside Honda on ebay, but when they are mounted on the bike, I cannot pivot the mirror low enough to see directly behind me. I compared them to the originals and it is obvious that the masts are bent at different angles. Southside claims these are the only ones America Honda offers. Does anyone know of a source for direct replacements?
Paul
63 CA78
OldScrambler
Do an ebay search for c100 and a dozen other small models of early Hondas..........they use mirrors with extra-long stem-threads to fasten with clamps..............cut the threads to the correct length (file for effect) and install them on the Scramblers..........they fit and can be adjusted so you can SEE behind you. Once installed they appear authentic and they are OEM Honda units.
The ones I got from Thailand had the correct length threads and adjust perfectly. Price may have gone up a little since I got mine. Look at these:OldScrambler wrote:Do an ebay search for c100 and a dozen other small models of early Hondas..........they use mirrors with extra-long stem-threads to fasten with clamps..............cut the threads to the correct length (file for effect) and install them on the Scramblers..........they fit and can be adjusted so you can SEE behind you. Once installed they appear authentic and they are OEM Honda units.
http://www.ebay.com/itm/HONDA-CB72-CB77 ... Lg&vxp=mtr
63 CA78
