Brickyard
Post by Brickyard » Fri Nov 13, 2015 2:50 pm
I had to do just a little bit of fiddling with the rotor bolt to "pull" the chain a litttle from the crank sprocket to match the cam sprocket, but wasn't difficult at all.
Ok, so after rotating the engine 360 a few times, after remains lined up.
The "spring loadedness" I was looking for at T actually came when the points cam was pointed down, and something tells me "that makes sense, I've seen this before" but I can't explain why.
LOUD MOUSE wrote:Must have been some job to get the chain on the sprocket.
You didn't get the same "T" as you came around?. .......lm
Post by LOUD MOUSE » Fri Nov 13, 2015 2:59 pm
Maybe I can explain.
To setup the cam to the crank timing is done like you understand.
However to set the cams you must rotate the crank so the points cam has the line down. ...................lm
Brickyard wrote:I had to do just a little bit of fiddling with the rotor bolt to "pull" the chain a litttle from the crank sprocket to match the cam sprocket, but wasn't difficult at all.
Brickyard
Post by Brickyard » Fri Nov 13, 2015 11:25 pm
Ah ha! Thanks for reminding me. I tried calling a number i found online for you, but maybe you changed your number because the phone rang and rang, and then turned into a fax machine.
LOUD MOUSE wrote:Maybe I can explain.
Brickyard
Post by Brickyard » Sun Nov 15, 2015 7:30 pm
Almost there folks! Should look like this in 2 days...
Brickyard
Post by Brickyard » Sun Nov 15, 2015 8:23 pm
Just learned that my front forks are from a previous year model. Never paid much attention to them other than the inspection sicker that expired 43 years ago (this guys an outlaw!).
Unfortunately they are way overdue for a rebuild and apparently I have to build a tool for that
-_-
Brickyard
Post by Brickyard » Wed Nov 18, 2015 4:02 am
Never have I ever heard sweeter sounds from anything else. I'm confident the donor Pistons and crankshaft were worth it. It's a new bike!
This was the very first start up and I'm happy to say it took 3 kicks:
https://m.youtube.com/watch?v=Q4KkTsnfN ... e=youtu.be
Post by LOUD MOUSE » Wed Nov 18, 2015 6:38 am
Nice and smooth. ...................lm
Brickyard wrote:Never have I ever heard sweeter sounds from anything else. I'm confident the donor Pistons and crankshaft were worth it. It's a new bike!
