1966 honda dream ca77 petcock question
I have been trying to remove these 3 screws. I have used. wd-40,pf blaster,liquid wrench, a mixture of 50/50 transmission fluid and acetone. I have had no luck. I have let it set for 2-3 days on all the fluids I mentioned. I even used a impact screwdriver,any ideas?
- ca77 petcock.JPG (72.62 KiB) Viewed 3941 times
For tough screws in difficult places (where you can't get vice grips on the heads) I usually grind up a small drift punch and try to get it to bite into the edge of the screw head by tapping with a hammer. If you can get it to bite in two places 180 degrees apart, you will probably get it to turn with lots of patience and lots of tapping.
If you are going to drill the heads, get a left-hand drill bit - they are cheap - and if you use lots of pressure, the bit will probably grab the screw head and turn it out.
Re: 1966 honda dream ca77 petcock question
Have you tried some de-rusting fluid inside the tank?
Those are JIS screws so worth getting them out in one piece if you can.
Try tightening the screws just a little with a good fitting screwdriver. The screw is often less damaged in the 'tightening' direction and that can often break the grip of corrosion.
choctaw wrote:I have been trying to remove these 3 screws. I have used. wd-40,pf blaster,liquid wrench, a mixture of 50/50 transmission fluid and acetone. I have had no luck. I have let it set for 2-3 days on all the fluids I mentioned. I even used a impact screwdriver,any ideas?
petcock screws
The last petcock I bought for my Dream had no screws. I tapped the holes with similar size SAE tap. You could also do metric. Both screws are plentiful.
Re: petcock screws
Ya right.
Those screws don't HAVE TO BE JIS. ..................lm
mike1969 wrote:The last petcock I bought for my Dream had no screws. I tapped the holes with similar size SAE tap. You could also do metric. Both screws are plentiful.
Re: petcock screws
True - if you got some taps, they can be any size you like, preferably metric to avoid Mr Honda turning in his grave...... :-)
I've enjoyed dismantling bikes from the US that have been held together with all sorts of farmyard fasteners.
LOUD MOUSE wrote:Ya right.
