Brickyard wrote:May someone please verify my piston ring setup. There's no clear direction to which ring goes where. I placed the black ring up top, copper/steel ring as second, only because my bad Pistons had a similar set up, except the copper/steel ring is black/steel on the old piston. There are no noticeable bevels in either ring. Thanks in advance.
You may want to ask Tim how they install. ..........lm
Thanks.
The top looks different with your last pic and I can now see the WISCO dome.
Thanks. ..............lm
Brickyard wrote:Wiseco Forged.
LOUD MOUSE wrote:Really.
What are they?. ................lm
Brickyard wrote:Thanks to classichondarestoration.com, the Toys-R-Us for CB77 owners.
LOUD MOUSE wrote:Nice pistons. ............lm
Brickyard wrote:New pistons and rings installed.
Got Bill Silvers engine book open to guide me through reassembly.
Will do.
I will hold off installing the top end until then.
LOUD MOUSE wrote:You may want to ask Tim how they install. ..........lm
Let us know what he says. . .............lm
Brickyard wrote:Will do.
At this point I'm pretty nervous as this is the first time I've split the cases and put them back together. The worry of "maybe I forgot something" is hard to overcome, but I checked and checked again. Bill Silver said an alternative to Hondabond is this permatex ultimate gasket maker; it's what I have, so it's what I'll use...
- image.jpg (66.9 KiB) Viewed 1587 times
- image.jpg (47.02 KiB) Viewed 1587 times
- image.jpg (56.75 KiB) Viewed 1587 times
Brickyard
Just use sparingly and keep it out of those oil galleries. Did you clean the oil filter after finding all that muck in the oilways?
Brickyard wrote:At this point I'm pretty nervous as this is the first time I've split the cases and put them back together. The worry of "maybe I forgot something" is hard to overcome, but I checked and checked again. Bill Silver said an alternative to Hondabond is this permatex ultimate gasket maker; it's what I have, so it's what I'll use...
I'm going to get a tube of that. ...............lm
