Cb72 fork swap
Tunster
Cb72 fork swap
Post by Tunster » Tue Sep 29, 2015 3:50 pm
Can anyone tell me if there are any forks that will swap directly into my 65 cb72 yolks and will use the original wheel. Mine had a plastic front mudguard held on by jubilee clips. Or should I restor my forks and weld some lugs on to mount the mudguard properly.
This is a race bike not original.
OldScrambler
Post by OldScrambler » Tue Sep 29, 2015 4:16 pm
Those steel legs look original..............its the fender that needs custom stays. Alloy legs from later models may be easier to work with.
Re: Cb72 fork swap
Post by G-Man » Wed Sep 30, 2015 1:37 am
Tunster
Welding brackets to those forks would need care as you might distort the tubes.
Forks from a later Honda, such as a CB250 / 350, could be fitted but they still wouldn't have a bracket for that particular mudguard. My racebike has a plastic mudguard with CB350 (I think) forks.
The steel CB160 / S90 front mudguard is popular for the '60s Honda GP look. See pic below....
Fitting your wheel to another set of forks isn't going to be a problem. The 15mm spindle size is fairly common. Even the GT750 Suzuki wheel in my racebike has a 15mm spindle.
Tunster wrote:Can anyone tell me if there are any forks that will swap directly into my 65 cb72 yolks and will use the original wheel. Mine had a plastic front mudguard held on by jubilee clips. Or should I restor my forks and weld some lugs on to mount the mudguard properly.
CB72 with_CYB_parts_fitted small.jpg (91.99 KiB) Viewed 5876 times
Tunster
Cb72 forks
Post by Tunster » Wed Sep 30, 2015 2:55 am
Thanks G-man I will see what's about at Stafford show. Distorting the tubes was a concern and the expensive of restoring them overall. I like the shorter mudguard but didn't like the jubilee clips. Thanks for the advise.
jerry
Post by jerry » Wed Sep 30, 2015 5:58 pm
Silver solder for mounts works well on the steel fork sliders. All the best Jerry
Post by G-Man » Thu Oct 01, 2015 12:54 am
Jerry
Great suggestion. Hadn't thought of that. :-)
jerry wrote:Silver solder for mounts works well on the steel fork sliders. All the best Jerry
