Tacho
modelman
Post by modelman » Fri Sep 18, 2015 6:27 am
New meter-decal applied, but I didn't fancy 'sticking' the meter onto the oval metal/rubber surround, so I carefully drilled through the frame & into the main shell, ground a point on a pair of stainless cap-head bolts.
So when they are fitted through the headlamp-shell, the points go into the holes & pull the unit tight down onto the rubber ring.
Another question, under the steering damper there is some sort of retainer at the rear of the head-stem bearing, what's it for??
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
PhilD
Tacho
Post by PhilD » Fri Sep 18, 2015 6:56 am
Hi model man,
Refurbished speedo revcounter looks good. Not sure what you're referring to with your question about the retainer at the rear of the lower steering stem bearing, there is an oblong projection which anchors the friction disc in the steering damper, is that what you mean? If not post a picture.
PhilD
1964 CB72
1964 CB77
modelman
Post by modelman » Fri Sep 18, 2015 7:01 am
Should have said under the damper KNOB, you can see it in the photo, its the folded pressed steel loopy thing!!
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Post by LOUD MOUSE » Fri Sep 18, 2015 7:07 am
To keep the steering damper knob from turning as you ride.
Hold the knob where you put it. .................lm
modelman wrote:Should have said under the damper KNOB, you can see it in the photo, its the folded pressed steel loopy thing!!
modelman
Post by modelman » Fri Sep 18, 2015 7:45 am
Ah yes, I see it now, I hadn't noticed the dimple & serrations, Thanks.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
