A little tip
modelman
A little tip
Post by modelman » Wed Aug 19, 2015 8:50 am
For those of you wishing to make your own rear shock-covers.
Mine weren't too good, ( plastic split ) so I looked around for steel tube, but I only needed a few inches & couldn't buy small amounts, looking around my local DIY store ( B & Q in the UK )
I found 60mm thin-wall bolt-on table legs, SPOT-ON !!
I'm often to be found lingering around various shops/stalls looking a 'junk' wondering 'what can I use that for' !!
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
DianneB
Post by DianneB » Wed Aug 19, 2015 9:40 am
Amazing! And ingenious to. Take an extra 15 minutes on your coffee break for a job well done ;)
Post by G-Man » Wed Aug 19, 2015 11:42 am
Modelman
Excellent work! Girling covers work well too (with a little internal spacer to centre the spring) but yours is a much more satisfying solution. :-)
This is a CL77 damper I restored and converted from crimped to screw construction.
Thanks for sharing.....
R100
Post by R100 » Wed Aug 19, 2015 12:31 pm
Excellent!
sarals
Post by sarals » Wed Aug 19, 2015 2:25 pm
Talk about ingenuity! Fantastic.
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
Post by Seadog » Wed Aug 19, 2015 5:49 pm
Great job! I assume you welded the top on the tube. That must have been tricky with such thin material.
modelman
Post by modelman » Sun Sep 06, 2015 7:52 am
Sorry I didn't reply. somehow missed this!!
Yes, I welded the top plate, I mig-welded it, turned it right down & then did a 'tack' then another & so on until it was all around, then cleaned it up on the belt-linisher.
Next job, cut out a cardboard template & make the chain-guard!!
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
