Camshaft for Dummies
modelman
Post by modelman » Tue Aug 11, 2015 7:23 am
Remember those "for dummies" books a while back, pity they never did one for CB77 camshaft installations.
Just got the head back from having the seats re-cut, carefully re-assembled the shafts, etc, valves,
rockers, went for a trial re-fit of the tacho drive housing, EH?? Its on the WRONG SIDE!!
YO-YO brain here only managed to fit the whole shooting-match the wrong way round, ALL the mount-holes are the same & both end castings fitted ok, worked fine as well!!
All my big bikes, things like this are impossible as the camshafts won't fit at all if the wrong way round.
Something to think about for those like me who've never done this before.
Ho-Hum, I always did learn the hard way.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Hahnda
Post by Hahnda » Tue Aug 11, 2015 7:59 am
Ihave done exactly the same thing one time. Haven't done it again since. I double check now!
modelman
Post by modelman » Wed Aug 12, 2015 1:20 pm
OK, its now the right way round (I think) but as you experts out there already know, once split, the points inner drive shaft will fit either way in its rectangular slot, looking at the pic, have I got it right, or is that now 180 out??
I can get the camshafts out in about 1 minute now !!
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
modelman
Post by modelman » Fri Aug 14, 2015 12:48 pm
C,mon fellas, you experts out there must know this, is this right or wrong??
Logic dictates that the slash on the cam is 'up', but at this position BOTH points are open, shouldn't one be closed at least??
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
R100
Post by R100 » Fri Aug 14, 2015 1:09 pm
Your picture looks correct.
Mark (o) on sprocket at 12:00 o'clock.
Line (l) on points shaft at 12:00 o'clock.
"T" on the alternator should be at the pointer.
modelman
Post by modelman » Fri Aug 14, 2015 3:21 pm
Thank you.
GSX1400 Red/silver
GSX1400 Blue
GS1000G
Brockhouse Corgi
CB77
CA77
T140
BSA 250
Post by LOUD MOUSE » Fri Aug 14, 2015 5:28 pm
You will need to turn the rotor one full turn to marker at "T" and that is where you set the Rocker clearance and then the timing at "F" to set the points. . ................lm
modelman wrote:C,mon fellas, you experts out there must know this, is this right or wrong??
