CB72-77 Racer
lloydy1
Post by lloydy1 » Sat Jun 20, 2015 2:22 am
G-Man wrote:Dave
Most of the gaskets would work but you would need to get a 64mm head gasket.
http://bore-tech.com/product/head-gaske ... g-bore-kit
Thanks G very helpful.
I was thinking about making up a copper gasket. What are your thoughts on this?
Dave
Post by G-Man » Sat Jun 20, 2015 2:39 am
Dave
Yes, a copper gasket should work. If the pistons and head have been closely matched you may need to be careful of teh clearance if the copper gasket is thinner.
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1
Post by lloydy1 » Sat Jun 20, 2015 3:44 am
G-Man wrote:Dave
Just measured the existing one and it comes out between 1.50 and 1.60mm. seems very thick.
I'll order a sheet of 1.50mm copper as it has no squash.
Dave
lloydy1 wrote:
G-Man wrote:Dave
Dave
Post by LOUD MOUSE » Sat Jun 20, 2015 4:08 am
I'm about to list a copper head gasket (1,11mm thick, 59.42 at the cylinder) on eBay. .................lm
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1
Post by lloydy1 » Sat Jun 20, 2015 5:50 am
LOUD MOUSE wrote:I'm about to list a copper head gasket (1,11mm thick, 59.42 at the cylinder) on eBay. .................lm
Hi...That maybe a little thin for my needs. This engine seems to have been messed with a bit and the squish may have been allowed for. If I install a thinner gasket I may run into problems.
Thanks Dave
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1 wrote:
G-Man wrote:Dave
Dave
Post by G-Man » Sat Jun 20, 2015 6:50 am
Dave
Dennis Murfin told me that he set his squish clearance by assembling the head without gasket, then made sure the engine "just" turned over. Then With the gasket in place you should have a bit of allowance for rod stretch when it is running at high speed.
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1 wrote:
G-Man wrote:Dave
Dave
lloydy1
Gear Changer and Box
Post by lloydy1 » Sat Jun 20, 2015 10:24 am
Some pics of the gear changer and box.
Looks pretty standard to me, other than the gear change mechanism. Any thoughts please?
Cheers Dave
