Super Slow 65 CB77 Restoration commences
jugger18
Post by jugger18 » Sat Dec 20, 2014 5:49 pm
So as time has passed since my call to ed my memory has faded a touch.
Well I decided to try it myself on this head and if I fail I will send Ed the second. I have the pins and rocker arms out now. Next is the Large nut next to the sprocket right? Remind me does that loosen towards the exhaust (punch downward on exhaust side)? Also the nut on the outside end of the shaft? Did that need to be removed? So far I have split a few pieces of wood (2x4 cuts) trying to lock the sprocket so I can remove the sprocket nut
Farm Shop
Post by Farm Shop » Sat Dec 20, 2014 7:11 pm
Yes the big nut is left hand threaded so punch down on exhaust side!
A vise grips on the other side of the sprocket works well to hold it.
The little nut only needs to be loosened way up and then drive on the bolt with a soft punch to knock the wedge lock loose. If you back the nut off flush with the end of the bolt you won't booger the threads!
jugger18
Post by jugger18 » Sat Dec 20, 2014 7:15 pm
Yep Ed got me straightened out, as he usually does with newbies like me. Nut is off and Points cam is out. Having fun trying to get the left cam to separate and come out./
jugger18
Post by jugger18 » Sat Dec 20, 2014 7:37 pm
Gave it the right persuasion and choice words and she is out.
jugger18
Post by jugger18 » Fri Jan 09, 2015 8:39 pm
I got off my but and split the cases. In talking with Ed, this should make it easier to free my severely stuck pistons..
Anything look crazily amiss here?
jugger18
Post by jugger18 » Thu Apr 02, 2015 8:06 pm
Well I have not done much recently with the bike. I have been working on a 1970 c70 as well. But I did just acquire these for the ridiculous price of $120 shipped :)
G3
Post by G3 » Fri Apr 03, 2015 12:23 am
"(Ed is) incredibly generous with his time and knowledge". Yep.
