Speedo drive confusion...
R100
Post by R100 » Fri Feb 13, 2015 9:46 am
Well G-Man, I was about to defer to your logic. No mystery about an early speedo (as long as it works), but difficult to know what I would be getting with a drive unit.
Then I found an E-Bay seller who checked his and described the rotation. Difficult to be certain not seeing it for myself, but at 1/3 the cost of a decent speedo it seemed worth a gamble. Shoul be here in about 10 days.
Wish me luck.
Post by G-Man » Fri Feb 13, 2015 10:51 am
Yes, good luck with that. Please let us know if you can identify the later one by appearance only.
R100
Post by R100 » Thu Feb 19, 2015 1:32 pm
I could not find anything exterior that would indicate CW or CCW rotation.
Luckily the E-Bay seller understood me and got it right.
What is the large Phillips screw for? Lubricating?
cw ccw 001.JPG (123.08 KiB) Viewed 2333 times
cw ccw 002.JPG (118.54 KiB) Viewed 2333 times
Post by LOUD MOUSE » Thu Feb 19, 2015 2:20 pm
Yes. ................lm
R100 wrote:I could not find anything exterior that would indicate CW or CCW rotation.
R100
Post by R100 » Thu Feb 19, 2015 2:28 pm
LOUD MOUSE wrote:Yes. ................lm
What's your recommendation LM?
Grease?
White lithium grease?
90 gear oil (I'm a big fan)?
Post by LOUD MOUSE » Thu Feb 19, 2015 2:36 pm
Unless you remove the part and flush/clean the old grease and just want to add some I recommend dinosaur grease.
If you do clean it I recommend High Temp Grease.(BLACK). ..........lm
Grease?
R100
Post by R100 » Thu Feb 19, 2015 2:43 pm
LOUD MOUSE wrote:Unless you remove the part and flush/clean the old grease and just want to add some I recommend dinosaur grease.
Grease?
Will go with my old standby - Belray Waterproof Grease
