wiring harness help
JonnyT
wiring harness help
Post by JonnyT » Mon Jan 12, 2015 2:51 pm
Guys..........I tape off and mark all my wiring before sending my 305 ca77 dream to the painter and what does he do? Takes off my tape and paints my wires. I've removed all the paint I can and cut back the covering, but things don't match up looking at the diagram. Were these diagrams always accurate? Does any have a real diagram of a '67 Honda dream 305 ca77?
mcmig
Re: wiring harness help
Post by mcmig » Tue Jan 13, 2015 3:05 pm
JonnyT wrote:Guys..........I tape off and mark all my wiring before sending my 305 ca77 dream to the painter and what does he do? Takes off my tape and paints my wires. I've removed all the paint I can and cut back the covering, but things don't match up looking at the diagram. Were these diagrams always accurate? Does any have a real diagram of a '67 Honda dream 305 ca77?
Here it is, attached:
Cheers,
C CA 72 77 Wiring diag in colour.jpg (143.98 KiB) Viewed 4371 times
pieeater
wiring
Post by pieeater » Fri Jan 16, 2015 1:24 pm
Hello
I have just finished the wiring on my CA77 and used this diag
The bk/y wire from the switch to the rear light was white on mine.
if its not broke don't fix it.
Aermacchi ss350
Gilera 124
James SC1 Scooter
Honda CA77
Dr. Frankenstein
COLORED wiring diagram!!
Post by Dr. Frankenstein » Fri Feb 13, 2015 7:58 am
THAT is awesome! I am all thumbs when it comes to figuring out where stuff goes in my Dream - you don't have one for a CA95, do you...? I'd like to find something like this for an aftermarket wiring harness that shows you what color goes to what...
Dr. Frankenstein
Post by Dr. Frankenstein » Fri Feb 13, 2015 8:14 am
...although on second thought, I guess all you really need is a set of magic markers...doh!
dreamneworleans
Where is the 15A fuse
Post by dreamneworleans » Tue Apr 14, 2015 9:43 pm
Hi. Great diagram. I have it but not in color. I have a 67 305 dream with a short.. It occurred when I switched the dimmer switch all the way down. How do I get to that fuse to check it?
Hahnda
Post by Hahnda » Tue Apr 14, 2015 10:05 pm
There is only one fuse and its next to the battery.
What you may have is a wire that has some of its insulation rubbed off as it passes through the handlebars.
