Thread size
cleg
Thread size
Post by cleg » Sat Dec 20, 2014 2:45 pm
Are the threads on the Superhawk left side crankshaft size 20x1.5 ? I bought a crank and the threads are messed up. I can't get the nut to thread on.
'66 CB77 '75 Rd125
Post by G-Man » Sat Dec 20, 2014 3:30 pm
Hi
I don't have one nearby to measure but you could check the pitch against a regular M10 bolt which is 1.5mm pitch. Honda use M10 fine normally do you need a regular M10 from a hardware store.
I'll measure one for you tomorrow if that helps.
Post by LOUD MOUSE » Sat Dec 20, 2014 4:09 pm
He stated NUT not Bolt.
Ya may want to file off the bad threads until you can get the nut to start. ..........lm
G-Man wrote:Hi
Post by G-Man » Sat Dec 20, 2014 4:20 pm
LM
You misunderstood me. I was just suggesting that he use an M10 bolt as a thread gauge to check that the pitch was 1.5mm.
He should be able to tidy up the thread with a needle file if it's not too bad.
The question was about what size the thread was on the crank.......
LOUD MOUSE wrote:He stated NUT not Bolt.
G-Man wrote:Hi
Post by G-Man » Sat Dec 20, 2014 4:25 pm
One of the could be handy for tidying up the crank end if it's not too bad.
http://www.ebay.com/itm/Thread-Restorer ... 4d2a389ba0
Post by LOUD MOUSE » Sat Dec 20, 2014 4:43 pm
It is a 1 pitch which is visible by eye to a 1.25 or 1.50.
We both recommended he file the shaft as to purchase a die for a one time use is expensive. ............lm ......................lm
G-Man wrote:LM
G-Man wrote:Hi
cleg
Post by cleg » Sun Dec 21, 2014 12:20 pm
Thanks guys. I ended up using a die grinder to get to some decent threads.
I have the left side together (a peek at LM's nice clutch). Does the stack on the crank look correct, before I tighten the nut with a spanner?
I've also attached a pic of my rebored and copper lined sleeves cylinder.
'66 CB77 '75 Rd125
