New here to the forum and after finding much useful information I decided to join! I am currently working on a ground up overhaul of a 67 scrambler. When ordering first over rings (.25) do these run in stock size pistons? Because all I can find is stock and .5 over pistons?
Thanks. Fs
first over piston size
Welcome to the Forum!
Piston rings are matched to the pistons. So +0.25 pistons go with +0.25 rings etc..
Find out what size your cylinders are and whether they need re-boring. Buy pistons to match the bores and rings to match the pistons.
You may need to check availability of pistons before having the cylinders rebored. They are not in plentiful supply and can be expensive. You need to work with your machine shop and bore the cylinders to whatever pistons you can get. Then the rings....
Good luck!
Good luck!
