Flickering lights, grounding issue on headlight CA72.
deafanddiabetic
Post by deafanddiabetic » Thu Oct 09, 2014 9:53 am
I presume you guys mean one of these? Will 12v be enough to light this sucker up?
Not that it matters, but the power source only comes from one wire jumped off the horn, I know that's plenty but for some reason I figured headlights needed a little more ooomph.
I will definitely try some JB Weld, I have some handy. Thanks for all the input, it's always the little things that keep you from riding, right? :p
mike1969
lights flickering
Post by mike1969 » Thu Oct 09, 2014 12:44 pm
Yep, that's the kind I put in my headlight. I bent the prongs flat so it wouldn't hit the speedo.
They put out enough light but they don't focus well. I put the bulb in only to pass Pa. state inspection and so I didn't have to spend a $150.00 plus on an nos one. I wouldn't recommend night riding on dark roads with this set up.
OldStan
Post by OldStan » Fri Oct 10, 2014 11:46 pm
12 volts is standard for this type bulb, but the wattage could be a problem if you run with the lights on. The amperage output on these bikes can be boarderline. You should use a 30 or 35 Watt bulb, that's what I have , its for scooter. As Mike said this style is not good for night riding, but good for daytime visibility.
63 CA78
Post by G-Man » Sat Oct 11, 2014 2:35 am
Paul Goff does some lower wattage halogen bulbs for older motorcycles...
http://www.norbsa02.freeuk.com/goffybulbs.htm
Also some neat LED lamps.
hondauser
H4 --------> LED
Post by hondauser » Sat Oct 11, 2014 3:44 am
Hy folk !!!
No longer necessary to turn around !!!
H4 LED bulbs are available --------> 2.7 W -------> start at 30 euros/pair in France !!!
is'nt that great ???
https://www.google.fr/search?q=h4+led&r ... CAgQ_AUoAQ
cb 72
cb 77 ,c77 ,cl77
velocette thruxton
malcolmgb
Post by malcolmgb » Sat Oct 11, 2014 6:25 am
G-Man wrote:Paul Goff does some lower wattage halogen bulbs for older motorcycles...
Great link Graham I didn't know about him.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
Post by G-Man » Sat Oct 11, 2014 1:53 pm
Malcolm
Yes, haven't bought anything yet but the choice is excellent.
