Have you looked at the dogs on all the gears?. ...........lm
apophis wrote:i am not sure which 2nd gear component gets the primary dog wear. The Mainshaft 2nd or the Countershaft 2nd
apophis wrote:im pulling the engine this weekend and should have the tranny open by sunday to do eval and measurements.
People were commenting they replaced their 2nd gear due to worn dog ears. I started looking at the microfiche and 2nd gear is marked as 2 parts. Mainshaft and Countershaft. I was wondering for those that had replaced2nd gear if its only (1) of these or do they mean "both" components of 2nd. It was unclear to me.
NOS countershaft 2nds seem readily available but mainshaft ones not so much.
apophis wrote:multiple delays, but I finally had time to pull the engine
I installed the .040 cotters. checked the shift forks. nothing bent our out of rounds. found that a shift pin was broken along with its roller. Had gouged the shift drum as well. I still have my original shift drum and have NOS shift pin, but no roller. have to order one
