mystery motor part please help
tom0811
Post by tom0811 » Fri Mar 14, 2014 4:49 pm
Hello, been lurking the forum and learned alot of good info, thanks. Now to my problem, I am rebuilding a 1965 305 motor and have it stripped down to the crankcase(havent split them yet) I found a smsmall pin in the bin that I have the motor in and I cant find it in the parts breakdowns that I have. Below is a drawing and dimensions. Thank You Tom
_| |_
|____ |
it is 6mm in diam in the thin part
it is 8mm in diam in the thicker part
it is 12mm in overall length
there is a dimple in the center of the thicker part
tom0811
Post by tom0811 » Fri Mar 14, 2014 4:51 pm
sorry. drawing didnt come out well. it is a round pin with a head on it that is thicker Will try to post pic tonight
Tinman
Post by Tinman » Fri Mar 14, 2014 4:57 pm
Pictures say a 1000 words, so to speak. And welcome to the forum.
tom0811
Post by tom0811 » Fri Mar 14, 2014 6:39 pm
hopefully this pic helps
Tinman
Post by Tinman » Fri Mar 14, 2014 9:35 pm
That looks like the pin for the oil filter. If you have the oil filter and shaft handy, see if the pin fits into the shaft and then slide the oil filter onto the shaft. On the backside of the filter, there is a notch milled out where the head of the pin fits into. Hopefully that's it, if not, perhaps somebody else will jump in with an idea.
jensey
Post by jensey » Sat Mar 15, 2014 1:37 am
Dimensions don't fit the oil filter pin which is much smaller.
I wonder of this part belongs to the CB72/77, I don't recall such a part.
Post by LOUD MOUSE » Sat Mar 15, 2014 7:57 am
Don't know that I've ever seen that part in a CB/CB72/77 engine. ............lm
tom0811 wrote:hopefully this pic helps
