Color decision
In deep now
The LH wrist pin is very seized in the rod. I split the cases and will press the pin out at work. I am thinking I will have to bore 1 over as the LH piston is pretty beat up and there are some marks in the cylinder wall. I wanted to send the jug to the guy I have used in the past for my RD400 boring but his boring bar only goes to 64mm. I also want to have the head looked at. I am in the St Louis area but do not know where to have the work done. Any suggestions?
- split.JPG (17.69 KiB) Viewed 2363 times
'66 CB77 '75 Rd125
Re: In deep now
That is the smallest?. ......lm
cleg wrote:The LH wrist pin is very seized in the rod. I split the cases and will press the pin out at work. I am thinking I will have to bore 1 over as the LH piston is pretty beat up and there are some marks in the cylinder wall. I wanted to send the jug to the guy I have used in the past for my RD400 boring but his boring bar only goes to 64mm. I also want to have the head looked at. I am in the St Louis area but do not know where to have the work done. Any suggestions?
Tim Miller
Bore jobs
I do percision boring & honing form .060" to 6.0"diameter cylinders in house. Hold +- .0002" taper and roundness on all honed cylinder work. PM me.
Tim
Tim
Re: Bore jobs
Good on ya Tim.
Now if they will send the part ya can be a great help. ...........lm
Tim Miller wrote:I do percision boring & honing form .060" to 6.0"diameter cylinders in house. Hold +- .0002" taper and roundness on all honed cylinder work. PM me.
Tim
