Does anybody know of a source for the ca77 advance springs (14329-259-310)? eBay has them for $40 for the pair, but that's a bit high. Or, can you substitute the cb/cl springs that are available?
Thx,
Tinman
Ca77 advance springs source
- Jims65CA77
- Jims65CA77
The DREAM spring is a touch longer than the CB/CL which are the same. ................lm
Jims65CA77 wrote:Yeah, I am new to the 305s and I just wanted to make sure you knew that the part numbers were different. I also found out the CL305 is different than the CB!
CL305 - 14321-268-020
Hopefully a true GURU will know.... ;^)
Good Luck!
- Jims65CA77
Not sure why, but the parts books for the CL and CB had listed them with different numbers. I suppose they could be "superseded" or something like that? Glad you cleared that up LM!LOUD MOUSE wrote:The DREAM spring is a touch longer than the CB/CL which are the same. ................lm
Good Luck!
Jim
