Another new guy restoring a 67 CB77
Post by davomoto » Sun Jan 29, 2012 12:41 pm
14-16 ft lbs for the 8mm nuts, 7-8 ft lbs for the 6mm nuts and bolts.
Davo
burnite2
Post by burnite2 » Sun Jan 29, 2012 12:58 pm
thanks davo
Post by davomoto » Sun Jan 29, 2012 10:46 pm
You're welcome!
burnite2
Post by burnite2 » Wed Feb 08, 2012 6:06 pm
its been awhile since the last up date. swing arm and center stand is on the frame.
walnut blasted the wheels and now polishing them up.
motor is being bead blasted.
im trying to get the rest of the paint done, but its taking forever.
i need to get this done before i deploy so i get to ride it.
Jeremy
burnite2
Post by burnite2 » Sun Feb 19, 2012 4:18 pm
Update on the bike: motor and frame back together, new shock covers, and brakes back together.
Still need a front fender, starter solenoid, starter chain, starter clutch parts, strater button/assem,
and all the cables. I can start to see the light at the end of the tunnel.
burnite2
Post by burnite2 » Sat Mar 03, 2012 9:43 pm
Wheels are done, starter mag switch in, triple clamps on, and mocking up the shift linkage.
Using a VW push rod with heim joints.
Muddy
Post by Muddy » Sun Mar 04, 2012 1:39 am
G'day burnite2
That bike is looking awesome and will look absolutely fantastic when finished.
Can I ask you about the glycerin on the rubber knee pads - I've never heard of that before - do you just rub it in and leave it sit for 24hours? Do you need to clean it off or does it just soak in?
That engine looks fantastic - is it just bead blasted or is actually painted?
Keep up the great work.
Thanks.
Regards
Muddy
'64 C72
'63 C72
