Well, now the "carb" versus "carbs" makes sense! Hang on to that stock carb, you may have trouble getting it to run right with the Mikuni carb! Avoid the all fiber clutch plates. There are some really great threads on this site explaining what parts to use for your clutch.
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
The air filter I ordered arrived. Problem is the gap between the carb intake and the gas tank support is too narrow for the air filter to fit. I'm thinking about putting a 90-degree elbow in there. Is that a bad idea?
Failing that, I might remove that spacer between the carb mount and the cylinder (see below photo):
Also, on the kickstarter side, should the key really be mounted below the seat here?
On a kind of different topic, where can I get tires like this? I need to replace the front- it's dryrotted.
Should I be concerned about this blemish on the tank? Is it some kind of patch job?
