Has anyone ever come across steering bearings for a CA77 that are enclosed instead of those little BB's?
-Sascha
Steering Bearings
This one should work.
SSH750
http://www.z1enterprises.com/detail.aspx?ID=1503
May find them cheaper if you search around.
SSH750
S; I just yesterday replaced the steering bearings on a CL77 with tapered bearings from "All Balls". the kit #22-1011 fit perfectly using the 3mm shim supplied. I thought of you and drug out a 305 dream frame, knocked out the bearings and measured. they are the same as the CL77/CB77. so the nuts of it is that the AllBalls kit #22-1011 will work on the 305 dream frame
Good luck
Randy
Good luck
Randy
