Side cover bolt set
Maverick
Side cover bolt set
Post by Maverick » Fri Sep 03, 2010 9:38 am
I bought a side cover bolt set for my 305 off Ebay and it leads you to believe it is a full set. It is a stainless steel allen head set. The set doesn't contain the long bolt on the left side that is in the front of the smaller cover. The seller says he doesn't have one to fit it. But in his ad you would think it's a full set. He does list the sizes in his set but until you pull all the bolts out you don't know the lengths of them. I have checked locally for one with no luck.
Does anyone know where you can buy just one bolt?
It looks to be about 115 mm long or about 4.5 inches.
gramey7
Post by gramey7 » Fri Sep 03, 2010 10:01 am
If you find a source, please share it. I have allen head bolts except the long one.
GeorgeP1111
Re: Side cover bolt set
Post by GeorgeP1111 » Fri Sep 03, 2010 10:03 am
Maverick wrote:Does anyone know where you can buy just one bolt?
Good question, I would like to find a source also. I just checked www.mcmaster.com and they only go as high as 80mm in Steel Philips Pan Head x6 and 90mm in Stainless. I suppose that if bad come to worse maybe the best bet would be to buy #6 threaded rod, cut to length, and use acorn (chrome?) caps.
George
Dgormley
Post by Dgormley » Fri Sep 03, 2010 10:18 am
Maverick and all, I,ll check my supply house(Tacoma Screw Products) today, I believe they have them but I'm not sure on the finish. Will post later with results..................D
Maverick
Post by Maverick » Fri Sep 03, 2010 10:57 am
I found a #6 120mm locally in black finish that would look good if not for the fact I have already bought stainless. I think the black would look pretty good.
Post by e3steve » Fri Sep 03, 2010 12:08 pm
I've fitted stainless 'cap' head Allens and managed to find a local supplier with just two M6 x 150mm bolts, with 20mm of thread (for those who are unfamiliar with engineering terms, 'bolts' are partially-threaded; fully-threaded are called 'machine' or 'set' screws). I carefully, slowly and with plenty of oil, threaded the extra with an M6 die and cut it to length.
It's an odd-sized bolt, for that location, so this may be the only option open to us?
Maverick
Post by Maverick » Fri Sep 03, 2010 12:52 pm
Fastenal has a 120mm but the local stores near me don't have them.
Not sure the threads are the same.
http://www.fastenal.com/web/search/prod ... dql8&Nty=0
