My 1965 Honda CA77 Revival.
I'm working on getting this motorcycle on the road. I'm trying Deaddog's method of rust removal in the gas tank using electrolysis. Here is a link to photo's documenting the procedure. http://s87.photobucket.com/albums/k159/ ... a%20Honda/ I want to get a car battery to do the procedure using 10 amps. Stay tuned!
1964-C77 305 Dream
2002 BMW R1150GS
2002 BMW R1150GS
I use this method for de-rusting tanks as well. I use an older, 10 amp battery charger that I found at a garge sale for $2.oo. I use large flat pieces of metal, not too lage or they'll ground out on the tank, and clean or change it every hour or so. I also use one wire out of romex from the + side of charger to the piece of metal for better current flow. You'll be pleased with the results, and it cost very little to do!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Here's a shot of the bolt after the first round of electrolysis.
I must say I am very impressed with the results so far. Rinsed out the tank and on to round two. In the meantime I removed my suspect rectifier and am going to have my electrical tech test it because I don't get the electrical stuff :( Here's the little bugger that was probably the reason my battery drained out.
Unfortunately, Radio Shack over here in Canada doesn't have the rectifiers the forum suggests. Neither does my local electronics place. Wierd. Cheers!
Unfortunately, Radio Shack over here in Canada doesn't have the rectifiers the forum suggests. Neither does my local electronics place. Wierd. Cheers!1964-C77 305 Dream
2002 BMW R1150GS
2002 BMW R1150GS
- h305 Moderator
Impressive (no pun!) results on that screw!Eljeef wrote:Here's a shot of the bolt after the first round of electrolysis......
Let me know if you want me to obtain and send you a rec & heatsink.
That's very kind of you. I found out today that my rec is toast. 3 out of 4 of the diodes are shot. I may yet take you up on that. :) Jeff H.e3steve wrote:Impressive (no pun!) results on that screw!
1964-C77 305 Dream
2002 BMW R1150GS
2002 BMW R1150GS
Wilf, would that be adequate for a Dream with all the turn signals? Jeff H.Wilf wrote:Eljeef,
The Radio Shack rectifiers (276-1185) are getting hard to find in Canada, but any bridge rectifier that meets or exceeds the specs (PIV of 50 volts or more, and Forward Current of 25 amps or more) will work just as well.
Wilf
1964-C77 305 Dream
2002 BMW R1150GS
2002 BMW R1150GS
