| Mileage: 11,487 Cleaned and regapped the spark plugs.
Went riding. Battery died. Pushed the bike into a service station and
put the battery on a charger for 1/2 hour. Rode home. Made a resolution to
solve the charging situation once and for all.
Stator
Checked the stator winding output
leads for continuity - all OK.
Checked for short to ground - no short to ground; the stator appears to be fine.
Selenium Rectifier [SR]
The bike has an aftermarket
rectifier; only four plates instead of the OE eight. The leads correspond to the OE
setup - Yellow, Red and Brown terminals.
The following current flow tests
were made in two series; the first using the 1964 SR and the second using the 1963 OE SR
from the parts donor CB77:
1964 Selenium Rectifier:
| Leads |
Y + R |
R + B |
Y + B |
15.4 Ohms |
86.7 Ohms |
101.1 Ohms |
15.5 Ohms |
85.1 Ohms |
100.1 Ohms |
| To Ground |
Yellow |
Red |
Brown |
| Ground = + |
7.62 kOhms |
7.64 kOhms |
7.73 kOhms |
| Ground = - |
13.21 kOhms |
13.21 kOhms |
13.27 kOhms |
1963 Selenium Rectifier - OE
| Leads |
Y + R |
R + B |
Y + B |
9.43 kOhms |
15.21 kOhms |
17.29 kOhms |
20.62 kOhms |
8.36 kOhms |
23.87 kOhms |
| To Ground |
Yellow |
Red |
Brown |
| Ground = + |
5.25 kOhms |
11.82 kOhms |
10.83 kOhms |
| Ground = - |
15.90 kOhms |
27.03 kOhms |
27.64 kOhms |
Two things stand
out immediately:
a) The aftermarket SR gives a reading in Ohms (between leads) vs. kOhms
as in the OE rectifier and
b) the
direction of current has no significant effect on the resistance
regardless of polarity.
From what little I know on this
topic, it appears that the 1964 SR is gone. The current is allowed to flow in both
directions without any hindrance whereas the 1963 SR appears to be OK, in theory, allowing
the current to flow toward the Red terminal (battery) and restricting its flow in the
opposite direction.
