1963 Honda CB77 |
1963 Honda Superhawk: Blue, decent chrome; all there, but needs attn much more than it needs new parts sought out. Needs: rewiring, cabling, seat foam & reapholstering, battery, orig toolkit, right side cover of toolkit/battery access area, front tire, carb work, plugs, new key cut (have orig key, but is bent yet workable, however it should be immediately used as a template for a new key @ a trusted locksmith w/ MANUAL keycutter machine only! automatic machines could botch the job & the orig key, so caution is noted here...). The clutch, gears & brakes all engage as they should; also, the wheels roll fine, meaning the bearings aren't shot. My wife's family were the 2nd owners (orig owners were next door neighbors, good story there) & had purchased it in the early '70's. |
