Motor installation
bonsaibill
Motor installation
Post by bonsaibill » Sun Feb 05, 2012 8:37 pm
What is the best way to put a motor in a rolling chasis dream? Manhandling doesn't work real well.
Dgormley
Motor install
Post by Dgormley » Sun Feb 05, 2012 10:44 pm
Bill, I'm not sure on dreams, but on Superhawks I've heard of folks lowering the frame onto the engine............................D
teazer
Post by teazer » Sun Feb 05, 2012 11:43 pm
On my Superhawks, I usually balance the motor on a low mechanics/garage seat and roll it into place. I keep a s couple of long rods the same diameter as the engine bolts rounded at the ends, but large phillips screwdrivers do just as well.
Roll engine into place.
Rotate rearwards to raise the front mount into the frame.
Insert screwdriver to hold the motor in place in the frame.
Swing the rear end up into place.
Insert another screwdriver into one of the rear engine mounts.
Fit all the bolts and tighten.
conbs
Put my engine back in
Post by conbs » Mon Feb 06, 2012 3:43 pm
I use a regular automotive floor jack with wheels and a piece of plywood between the jack and motor. Roll it in from the side and lift it into place. A small one is pretty chaep and will do the job, but a bigger one will work. If yo don't have one, can you borrow one?
Re: Put my engine back in
Post by LOUD MOUSE » Mon Feb 06, 2012 3:59 pm
Me too. ............lm
conbs wrote:I use a regular automotive floor jack with wheels and a piece of plywood between the jack and motor. Roll it in from the side and lift it into place. A small one is pretty chaep and will do the job, but a bigger one will work. If yo don't have one, can you borrow one?
Post by davomoto » Mon Feb 06, 2012 9:09 pm
LOUD MOUSE wrote:Me too. ............lm
Me three
bbap
Post by bbap » Mon Feb 06, 2012 9:36 pm
I'm as strong or stonger than most bulls and I also used a floor jack with a piece of foam and plywood to press it up into the frame. No need to ruin ones back when harbor freight or sears is just around the bend. :)
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
