Top end
versuspop
Top end
Post by versuspop » Tue Aug 09, 2011 6:11 pm
So I am confused. If I replace valves etc, how do I get the camshaft positioned back to tdc ? I have the engine apart to replace pistons and rings, but I am considering new valves too. What other work is recommended for the top end? Isn't there something with the seats that I should do also?
65 CA77
66 CB77
71 CB450
73 CB350F
Re: Top end
Post by LOUD MOUSE » Tue Aug 09, 2011 7:43 pm
If ya replace the valves ya will for sure need to cut new seats.
In my experience Head/Valve work isn't for a garage mechanic. ............lm
versuspop wrote:So I am confused. If I replace valves etc, how do I get the camshaft positioned back to tdc ? I have the engine apart to replace pistons and rings, but I am considering new valves too. What other work is recommended for the top end? Isn't there something with the seats that I should do also?
versuspop
Post by versuspop » Tue Aug 09, 2011 8:49 pm
Good to know. For reference, are there markers on the cam to know that it is in tdc position?
65 CA77
66 CB77
71 CB450
73 CB350F
Post by LOUD MOUSE » Tue Aug 09, 2011 9:31 pm
On the right side of the cam sprocket ya will see a dot or zero that is the top to have the cam at when ya install the cam chain. ............lm
versuspop wrote:Good to know. For reference, are there markers on the cam to know that it is in tdc position?
versuspop
Post by versuspop » Tue Aug 09, 2011 10:34 pm
Thanks Ed.
65 CA77
66 CB77
71 CB450
73 CB350F
versuspop
Post by versuspop » Wed Aug 10, 2011 8:55 am
is there a way to check the valves (and how well they close) with the top end apart? I read something in another post about kerosene and seepage, but did not understand.
Ed- are you still doing any work on top end/ valve stuff? :)
65 CA77
66 CB77
71 CB450
73 CB350F
Post by LOUD MOUSE » Wed Aug 10, 2011 10:08 am
Install plug, valves closed, fill to Over Valve surface (I use acetone as it evaporates quickly), look into intake/exhaust ports for sign of leak. ...........lm
versuspop wrote:is there a way to check the valves (and how well they close) with the top end apart? I read something in another post about kerosene and seepage, but did not understand.
