Crank seal tab
Kthomas55
Crank seal tab
Post by Kthomas55 » Tue Apr 09, 2019 8:35 pm
I didn’t notice the tab on the crank seal whenever I put it in. I put it on and then closed up the cases . Has anyone done this and left it as is . I really don’t want to buy a new seal or split the cases again as I have everything torqued down with sealant . It looks like the position makes no difference but ? It also looks like the seal will be fine as the tab is small . Any thoughts ?
Re: Crank seal tab
Post by LOUD MOUSE » Wed Apr 10, 2019 6:10 am
Not to worry.
That tab is to help keep the seal in place as the cases are put together. ................lm
Kthomas55 wrote:I didn’t notice the tab on the crank seal whenever I put it in. I put it on and then closed up the cases . Has anyone done this and left it as is . I really don’t want to buy a new seal or split the cases again as I have everything torqued down with sealant . It looks like the position makes no difference but ? It also looks like the seal will be fine as the tab is small . Any thoughts ?
Kthomas55
Post by Kthomas55 » Wed Apr 10, 2019 8:00 am
Thanks for the reply
It’s nice having a knowledgeable resource such as yourself.
Post by LOUD MOUSE » Wed Apr 10, 2019 11:21 am
You are welcome. .................lm
Kthomas55 wrote:Thanks for the reply
