Heads/cylinders
cushmanscooter
Heads/cylinders
Post by cushmanscooter » Tue Jan 05, 2016 4:11 pm
General questions, Are CA, CB, and CL heads interchangeable?? Also, same question for the cylinders?? Please reply this post or. hal-lee@att.net
Re: Heads/cylinders
Post by LOUD MOUSE » Tue Jan 05, 2016 4:37 pm
The heads are different when you change from the 250 to the 305.
CA heads are single carb so not recommended to install on the CB/CL engines.
The CB/CL heads can be used with either engine as the actual difference is the cams. ...................lm
cushmanscooter wrote:General questions, Are CA, CB, and CL heads interchangeable?? Also, same question for the cylinders?? Please reply this post or. hal-lee@att.net
honda brian
Post by honda brian » Fri Jan 08, 2016 5:35 pm
Hi all, regarding the barrel question. The barrels can be 8 hole or 9 hole. Make sure you use the correct one.
Regards, Brian.
