CB77 front axle spacer?
klp
Post by klp » Sat Feb 28, 2015 3:58 pm
I am trying to assemble my front end and it came with no spacers. All of the fiche I have found shows an earlier assembly not like mine. I think my bike is a 64.
Can someone provide me a pic of the axle off the bike and maybe some close up shots of each side assembled?
Thanks!!
KP
Post by G-Man » Sat Feb 28, 2015 4:09 pm
alloy fork lowers?
klp
Post by klp » Sat Feb 28, 2015 6:12 pm
Hahaa - I knew I was leaving out some details. My lowers are steel with the threaded cover that contains the oil seal.
The axle has a hole on one end with a raised section about 2" long opposite the threaded part.
klp
Post by klp » Sat Feb 28, 2015 6:28 pm
As near as I can tell this is the spacer I need but I can't figure out where it goes or how it fits. My wheel installed almost looks like it needs spacers on either side in order to center the wheel. The speedo drive is in place.
http://www.ebay.com/itm/291313786488?_t ... EBIDX%3AIT
Hoosier Tom
Post by Hoosier Tom » Sat Feb 28, 2015 6:35 pm
There are no extra spacers on the steel slider forks that I have had. The speedo gear box is the only spacer. The axle goes through the left side with the speedo gear box, threaded end and nut on the right side. The thicker end gets secured by a pinch bolt in the left steel slider. Pics may help get your situation sorted out.
HT
klp
Post by klp » Sat Feb 28, 2015 6:53 pm
Ohhhhh... It came with some wacky spacer that I knew was not right. I never considered no spacer!
I think my wheel is in backwards? I have the speedo drive on the right side when on the bike. This puts the brake plate on the left.
I am more confused now than before I posted! Feels like I am heading in the right direction though lol.
Hoosier Tom
Post by Hoosier Tom » Sat Feb 28, 2015 7:13 pm
klp wrote: I have the speedo drive on the right side when on the bike. This puts the brake plate on the left.
That's the way it is supposed to be. Do you have the steel sliders on the correct sides? There is a left one and a right one, each unique.
klp wrote:I am more confused now than before I posted!
That's why I suggested photos so we can see what you are dealing with.
HT
