NA082 Key WantedNA082 Key WantedLast item required to get my Barn Fresh (Original patina-white & rust, complete all original parts ) 1965 CA77 on the road.
Oil change, cleaned the petcock, squirt of penetrating oil in cylinders, cleaned the carb, jumped the ignition - Started 1st push of the button! I have had this bike in my basement 25+ years without touching it. Now I've whet my appetite to move onto the CL77 and CB77 I have also had for ages! - I think the CL77 is going to be a re-furbish project as it is 95% complete - I'm sure the other 5% will be expensive , if available! :) Honda KeysDid you try www.hondakeys.com?
Re: NA082 Key WantedMy list shows I may have 1 left.
I can check if you like. .......lm
Re: NA082 Key WantedWould you happen to have a nb369 Thanks Joey!
