are kenig hi comp.pistons any good ??are kenig hi comp.pistons any good ??are these pistons any good and will i have to make them fit my ca77 if there for a cb77?
Re: are kenig hi comp.pistons any good ??If you use CB77 pistons in a CA77 engine you will decrease the compression which will lower the power some. ...........lm
After HONDA lowered the compression (lower dome) early in production the domes of the CA77 and CB/CL77 pistons have the same height from the wrist pin.
The visible difference is the CB/CL77 piston is machined around the top edge where the CA77 is a full Hemi (dome) on the top. ............lm
