Sticking Throttle
Tom W.
Sticking Throttle
Post by Tom W. » Fri Sep 09, 2005 10:24 am
I've gone over both front and rear brakes and I think I'm almost ready for the first ride! However the sticking throttle is making me nervous.<br /><br />I've taken the carburetor slides out. Only the slides but have left the carbs on the motor. Sprayed both it and the carbs with cleaner. Wiped the outside of the slides and the bore of the carbs down real good so the slides will just fall down into the carbs. I've taken the springs out and streched them a bit so they have a bit more umph. I've take the throttle grip apart and lightly greased everything with white lithium. The throttle cables are old but I dripped light oil down the housings. But after all this the throttle still sticks. If I open the throttle full and let go, it'll return slowly and never all the way back.<br /><br />It seems like the cable has the most drag. Do new throttle cables slide much easier? Or should I try to find stiffer springs?<br /><br />Thanks,<br />Tom
kustommusic
Re: Sticking Throttle
Post by kustommusic » Fri Sep 09, 2005 4:51 pm
Tom, did you also look at the throttle tube that turns on the handlebar? and the mechinism that turns inside the housing on the handlebar? I believe if I suspected the cable and housing,I would seperate it where it splits and see how each half works independantly. Iv'e run into cars with throttle cables that are perfect looking but have worn a groove into the inside of the housing and caused them to stick,mabey thats it. Just a guess,,,,,,,Steve Greer
Tom W.
Post by Tom W. » Sun Oct 02, 2005 11:15 pm
I found some aftermarket throttle cables. These have a plastic body at the 1 to 2 split. I'll make a report after I install them (I'll probably ride the bike until the tank is empty).<br /><br />Tom
