As I reassemble my engine, after a 30 year hiatus, I was puzzled by what appears to be an oil distribution line. This is on the top of the engine top case. I cannot find it on any oil system flow diagram and wonder if anyone can tell me where it goes?
Here is a description of where it is. The oil from the upper engine case emerges from a hole on the top case in front of, and between, the cylinders. Then it goes up into the cylinder, where it splits and runs up along each of the forward/outer cylinder studs to lubricate the cam bearings, rockers, etc. At the bottom of the right hand forward stud, there is a groove cast in to the upper engine case that ends at a jet which appears to partially restrict oil flow so that a controlled amount runs back down into the engine case. Does this oil go to the outer right crankshaft bearing, or to ...?
Is it considered a mortal sin to re use piston pin clips?
Just wondering,
Larry in Pasadena
Mystery oil passage on 63 CB77
redblk63
pictures of oil path to right crank bearing
OK, here is the picture of the oil passage i wondered about. I also added pictures of the frame after i knocked off most of the rust and painted it. Can't wait to get the engine back together and fire her up!
Larry in Pasadena
Larry in Pasadena
